Will LapTimer work on iPhone while using bluetooth headset?
mizzoumike
Post by mizzoumike »
I recently found a product that lets you use your phone to communicate with another driver or someone in the pit while on track.
http://www.sena.com/product/intercoms/smh5/
It's a device that clips to your helmet, attaches to a headset you can put in your helmet, and uses Bluetooth to connect to your phone. I'm curious if this device could be used while recording video and data with LapTimer. Anyone have any experience with this or know a reason why the phone couldn't do both at the same time?
Re: Will LapTimer work on iPhone while using bluetooth heads
LapTimer requires to be in foreground while recording. In case this is possible while using the head set, it can work. But it is quite some load you put onto your phone, video + data recording with all the sensors engaged is tough already.
