Go trigger direction.
limpabit
Post by limpabit »
Hello everyone. Great app.
I'm using a Iphone 3GS with the Tomtom device. Started to have a play and wanted to test my setup. So done a test run.
Set a go trigger and a stop trigger. Now all works ok and triggers from the go trigger until the stop trigger.
My problem is I want it to start the go trigger in the north (default 360/0) direction. I approached the go trigger at approximately the 180 direction.
LT started to record from then, around the car park to turn round and back in the correct (360/0).
Is there any way to get LT to ignore the trigger if coming from a different direction?
Re: Go trigger direction.
No, currently not...
