[SOLVED] Changing track after the logging
wdepaepe
Post by wdepaepe »
Is it possible to change the track category after the logging has been done? Sometimes I start logging and afterwards I notice that I should have changed the track. E.g. Just for testing purposes, I am logging the time from home to the office and back. The way back is slightly different so I want both ways categorized seperately. But sometimes I forget to change tracks. Anyone has a tip to change the track to office->home when I have arrived at home?
Re: Changing track after the logging
Lap List -> select the lap to change -> Lap Details -> Edit -> Track -> select track to sort lap to
So the trick is pressing the Edit button in between. Otherwise you will end yourself in the Data Recording area.
