Laptimer Freezing up - Restored Iphone - No Improvement
dookie454
Post by dookie454 »
Hello, I previously used Laptimer with my Iphone 5 no problems... I've upgraded to I6 and not sure if that's the problem or what, but now no matter what I do, I cannot get it to work properly.
1) The bluetooth signal drops out every 10-20 seconds, for 10 seconds or so...
2) If I try to enter certain vehicles on the vehicle list... it completely freezes up after 3-4 seconds while trying to scroll the vehicle info... it will stay frozen until I exit the program. Then, Force closing gets laptimer back to running... but doesnt fix the problems.
3) some other menu's lock up as well... not sure exactly what ones, but i just accidentally went into "Video List" then "Multicam Icloud" and it's frozen...
I restored Iphone from 8.1.1 to 8.1.2 and re-synced, which reinstalled Laptimer... but still the problems persist...
Any suggestions? Thanks
Dan
Hi Dan,
For #1, please add the device you are attaching. For #2 there is an issue with media server access starting with iOS8.1 This problem generates issues in Vehicle Details, Video List and others. You may disable Photo and Video access in iOS's Settings / Privacy for LapTimer to work around the crashes / freezes, but it certainly disabled any video functionally. I plan to release a bug fix release (including a work around for the media server's misbehavior) early in January.
dookie454
Re: Laptimer Freezing up - Restored Iphone - No Improvement
Post by dookie454 »
Yes forgot to mention video disabled itself the second time I tried recording.
Its the Goppint BT1... Not too concerned with the dropouts at the moment. Since I had the video window open (before it disabled itself)... Prob had something to do with it.
Ok, good for now... Thanks!
