GPS out of sync / OBD drops out with Kiwi-style Adapter
spets
Post by spets »
Please take a look at the following YouTube video:
http://www.youtube.com/watch?v=bbSQac9KxkQ
I am using an iPhone 4. I did not change any sync/delay settings. Using Harry's Laptimer V.14. I am using the internal GPS and a cheap version of the Kiwi Wifi OBD sensor. I manually started the video record (did not use a trigger).
In the video, the GPS data is not matching up to where I am on the track. The MPH speed seems to be OK, but G-force and track position indicators are "off". Also, the OBD data drops out quite frequently.
Could there be some code optimizations to the way Harry's Laptimer picks up and uses OBD data? Or is it just the fault of the Wifi style adapter? Is there a wired iPhone-compatable OBD plug-in alternative? Any suggestions on syncing the G-force plot and position location?
Any advice would be appreciated :)
Re: GPS out of sync / OBD drops out with Kiwi-style Adapter
Looking into the video, my impression is that GPS, acceleration, OBD are approximately in sync. The video is not in line with this. Please check the following: play with the expert setting 'Overlay Synchronization' and try overlaying (the original video) again. In case the available range is not sufficient, you need to cut off the end if the video so it fits the GPS recording.
With manual recording, synchronization needs some more work from my side, I know ;-)
