IOS 8.1 with Iphone 6 Plus Hang after overlay.
Ronnie
Post by Ronnie »
Hi i am using Iphone 6 Plus with IOS 8.1.
I am using Harry's Laptimer for Karting purposes and one session will have around 16 to 20 over laps. I have record the video using the front camera and multi-cam connection to GoPro.
Problem happen when I tried to overlay the data. After overlaying is completed. The screen prompt to say ok to continue. I press ok and the app go back to the lap list and freezes.
I have checked. The Overlayed video is being save into the camera roll. However I cannot keep restarting the app for every lap. Is there a way to fix it.
Re: IOS 8.1 with Iphone 6 Plus Hang after overlay.
Which version of LapTimer do you use? Latest? First report like this, probably some configuration issue. Can you please check if LapTimer had received all permissions requested? Namely photo library access, cam+mic etc. please check the Privacy section in iOS's Settings.
Ronnie
Post by Ronnie »
Hi, I am using harry laptimer Grand Prix edition v18.3.6
I tried closing all other apps. It sonetime works now
You may try rebooting the phone before you run an overlay. This cleans up everything and give LT max memory... Shouldn't be necessary, but maybe it helps to understand where the problem is.
Ronnie
Post by Ronnie »
Noted and thanks. Btw can we overlay one entire track day in one good?
You can overlay a session (i.e. a number of consecutive laps) in one action - just extend the lap range from a single laps to the full session range in "Overlay Configuration".
