Autocross setup dialog closes when phone rotated
Posted: Sat Nov 01, 2014 3:54 pm
App is working well on android and major kudos for fixing the autocross dialog closing when the screen times out! Used it last month and was able to sleep the phone and walk the track and wake and tag the endpoint. Very helpful!
One small issue is that if you rotate the phone while the autocross setup dialog is open it will close and if you then choose autocross again it will have lost the start point. Again, a minor issue just reporting to let you know.
Thanks again!
Vince
Thanks again!
Vince
