Autocross setup dialog closes when phone rotated
vmbray
Post by vmbray »
App is working well on android and major kudos for fixing the autocross dialog closing when the screen times out! Used it last month and was able to sleep the phone and walk the track and wake and tag the endpoint. Very helpful!
One small issue is that if you rotate the phone while the autocross setup dialog is open it will close and if you then choose autocross again it will have lost the start point. Again, a minor issue just reporting to let you know.
Thanks again!
Vince
Re: Autocross setup dialog closes when phone rotated
Yes, I'm aware, when rotated, the whole front end is recreated and loses the transient state.
