Where doe G meter originate?
froggy47
Post by froggy47 »
From phone accelerometer or from the gps function?
I have motox/android and dual 160
The g meter is off even when standing still.
I thought I understood that it would calibrate with a hard brake (abs engage) or two but by the 10th lap the meter was still off.
Thanks.
Autox & HPDE
2004 Corvette Z06
Re: Where doe G meter originate?
Measured acceleration (the default) is recorded from the accelerometer. Only in case this fails, you may calculate acceleration from GPS (Lap List -> lap -> Recalculate -> Acceleration). The process to calibrate needs to follow this pattern: while standing still on flat surface in the pits, add your smartphone to the mount. In case you rotated the device, LapTimer will prompt you to confirm your phone is in the final position. Do not confirm until you have fixed the device. Once you confirm, LapTimer will calibrate the accelerometer to compensate gravity and tilt. The step performed on track is compensation of yaw. You should see a roughly zero overall acceleration (center of circle etc) before you start to drive.
In case you start driving without the initial calibration steps finished, LapTimer will not calibrate on track. A typical issue is when mounting he device while driving all track already. This does not work and is discouraged for safety reasons anyway.
For more information, please search the forum. There are lots of threads on this already.
froggy47
Post by froggy47 »
Autox & HPDE
2004 Corvette Z06
