Intermittent comms with ODB BT1
kulbrand
Post by kulbrand »
Hi Harry, firstly thanks for a great app.
Have recently seen intermittent comms with the GoPoint BT1 unit. Works for a while 30-60 seconds, then stops, some times when on see gears shows one higher than actual and for some reason the speed shows 0 constantly. Though when ODB data disappears the speed comes back, off for a shorter time, then comes back again. This is in reference to timing screen with video; ODB data right bottom and speed & time left bottom.
The ODB rate shows red and zero all the time, in the GPS screen. Tried phone reset, bluetooth re-connect, ...
I am using iPhone 6, IOS 8.02, latest GP edition v18.3.4. (I am going to try an old 4 phone with IOS 7.1.3 and see if similar)
Might there be hardware problem with BT1 (year old latest firmware) or something in software still not totally cleared up?
Sent a log file from GPS buddy, just now, not sure how will show up, maybe look for first name, anyway above is context, and what to add is the car is 2013 BMW M5.
Anyone else seeing anything similar?
Omar
Re: Intermittent comms with ODB BT1
There are no known issues with iPh6/iOS8.02/LT18.3.4 and the BT1. My first guess on situations like this is some disturbing other Bluetooth device or car stereo. So please recheck if you have any other smartphones etc with you either in "discovery mode" searching for peer devices, or even connecting the to BT1 in parallel. The later is a frequent effect when people start using a new smartphone.
The log you sent is too short. Ideally you generate one that includes a some range with the BT1 working, as well as the dropping situation. So please feel free to submit another log file with a longer time range.
All the effects described above are connection drops. Once the connection drops, GPS speed is used and will replace OBD speed. With no valid OBD speed, gears are screwed up etc. So these are all effects from an issue on device / connection level.
kulbrand
Post by kulbrand »
Thank you, think you are right. Tried in my other car 2008 128 and seamed to work ok there, although I had one brief complete drop out, refresh rate being 5-6 Hz. In the M5 still same problem, having turned off BT on stereo (also tried again stereo off and made sure no other BT devices around other than phone, at least that I know off.
Tried to submit another log file, hope I did this right, went for a drive recorded in Laptimer, and submitted the existing one from GPS buddy.
BT1 faulty ???
Omar
M54ccibo
Post by M54ccibo »
FWIW, I had an issue with my 2013 F10 M5 using the BT1 as well. I am also using an iPhone 6, IOS 8.0.2, and HLT 18.3.4. Constantly received a warning about OBD II update rate. For reference I had zero issues with Dash Command.
I decided to manually exclude a bunch of the OBD PIDs, and it looks like that worked. Wish I had come across that earlier. No biggie, as I excluded the OBD II data (which only had one entry in the CSV export) and utilized GPS speed for my video overlay.
For reference, here is the PID exclusion string which is excludes everything but VIN (0902), Throttle position (0111), Vehicle speed (010D) and Engine RPM (010C). I know that Harry suggests just removing a handful of the PIDs for rate issues, but since I don't need the others I just excluded them all:
09200940015C09000140012F0120011C010601050101010B0110
PS: I need to correct my above answer. There are known issues with intermittent BT disconnects for iOS8.0.2. I assume they will be fixed in iOS8.1 expected later this month.
kulbrand
Post by kulbrand »
M54ccibo, thanks for tips, will try. Force sequential to ON makes it work, at a stable 2-3 Hz refresh, when OFF the BT comms falls over immediately, turn to ON works again.
Harry, tanks for note on BT1. Just FYI, tried on my 2008 128i again and both modes work well "Force seq" ON 4 Hz, OFF 6 Hz, both stable.
Omar
