Fuel Gauget
gustavo
Fuel Gauget
Post by gustavo »
Hello, i cant see my fuel gauget working, it shows up but without the white pointer like the water temp. Im using OBD2 ELM device and my car is a Hyundai Azera 2010. Thank you.
Re: Fuel Gauget
Please check if your car supports fuel level PIDs: goto the GPS View with the OBD connected. You will see RPMs and one PID in the bottom right. Cycle through the values by touching this field repeatedly. In case Tank appears, does it show something reasonable? In case it doesn't appear, you car does not support this PID.
gustavo
Re: Fuel Gauget
Post by gustavo »
Hi , thanks for the reply.
in Tank, it shows 100% when i have only 50% fuel.
How can i get the gauget working?
Thank you.
Re: Fuel Gauget
Change the car's sensor :-) or the car :-) There is actually nothing you can do except that. Fuel level 100% is often reported with some fuel missing already, but at 50% it is pretty extreme...
