Lineal Acceleration Measurement and G-G Alignment
GeneRL
Post by GeneRL »
I am using the Laptimer for brake testing and using speed, g-level and distance. In the G-G chart there is an alignment button to rotate the data for better longitudinal alignment, once adjusted is this data change permanent and will it export with the correction?
Gene
Re: Lineal Acceleration Measurement and G-G Alignment
The controls in the G-G rotate acceleration keeping the overall acceleration. Changes are permanent and are exported.
