Derive Nordschleife BTG lap time from Nordschleife Full data
shaneeudy
Post by shaneeudy »
I just recently did a track day at the Nordschleife so I was using the full track set. Is there any way to derive a BTG time from this data?
Re: Derive Nordschleife BTG lap time from Nordschleife Full
Try the following: export the full lap to NMEA or VBO or GPX and send it per mail to yourself. Load the BTG track set. Open mail and touch the file exported. Select LapTimer to open this file.
shaneeudy
Post by shaneeudy »
I tried all three and each time I got the message "LapTimer read import successfully but could not recognize any laps. Please check if the matching track set is loaded."
Ok. Please send any of these to me and I will check (Harry@gps-laptimer.de), please use the session scope, I assume you have several continuous laps recorded?
shaneeudy
Post by shaneeudy »
Ah, that's it. I was exporting only one lap. Exporting Seasion did it. Thank you so much!
Yes, seems I need to improve the error message. LapTimer requires both the start and the finish trigger areas as part of the import to detect a full lap. So it is possible to import full laps starting at Döttinger Höhe (both bridge and gantry included), but not full laps starting at T13 (start not included - in the beginning). A session export can combine laps from consecutive laps.
shaneeudy
Post by shaneeudy »
As soon as you said "session" I knew exactly what had happened. (And I felt like an idiot because, of course, laps started at T13 do not include the Bridge starting point of the BTG lap.) I'm so glad I didn't delete the short "lap #0" that preceded the real lap :)
Thanks again so much for your help.
