Mounting (Landscape or Portrait) and more
llan981
Post by llan981 »
I have an IPhone 5S 64G, and plan to take HD video at a 2 track event for 30min runs for a total of 8 runs during the event.
1) Is it best to mount IPhone landscape or Portrait to gain the best performance on g-force or other benefits?
2) If I "start driving" in the main menu and it puts me in 'racer mode" then I hit the "Video Button" if I "Record Now" and hit the "X" in portrait it goes to "Racer View" which I like but in portrait it goes only to map view?
3) Can I do IPhone 5S and Go Pro and get to Racer mode in Landscape?
4) Is there an external MIC option you recommend via bluetooth that can be used to pick up at the rear number exhaust and engine?
5) I plan to be at 7 different tracks this year and will export all the data to dropbox. Next year when I revisit a track can I reimport to HLT the data to a specific track to my iPhone so I can compare all the track data?
6) What is the best way to push all the data, CSV, files, video, off the iPhone to another storage device after a track weekend? In other words, how can I archive date the best way??? For example should I overlay first?
Overall, what is the optimum best mounting configuration for best analytics while on the track.
Re: Mounting (Landscape or Portrait) and more
1) in case you want to record video in parallel, landscape is the only option
2) try the Timer view - it is the best for driving; to record video in parallel, press Video, press Record Auto (and you will be back in Timer view)
3) see 2) The racer view will not be further maintained (or expanded to landscape) as it is simply to detailed for on track use
4) check LapTimer / Accessories / Audio; there are only a few threads, one includes a proven solutions
5) there is no need to unload / reload data (except video); for backup / restore, please use the .hlptrl export
6) my recommendation is to overlay what is worth overlaying and delete the raw video afterwards (space); move the overlaid video to your desktop (from Photo app) and keep the data recordings on your phone; backup - see above
My mount recommendation is linked here: http://www.gps-laptimer.de/Compatibility.html
