Export video with overlay except lap time
fasteddie84
Post by fasteddie84 »
I have just started using the lap timer and come back from a track day and I now want to export a video of a single lap and want the overlap apart from the lap time as we are not allowed to time ourselves.
Is this possible?
Re: Export video with overlay except lap time
There is an option available in Overlay Configuration. For iOS swipe to the left, for Android, scroll down.
fasteddie84
Thanks, found that but it has the split times on it.
Is there a way of removing these?
I may be able to get away with just having the split times but if they are easy to remove, then it's probably best I do that.
You can delete the split triggers from the track set and overlay afterwards. Do not forget to reload the track set afterwards.
xps911
Post by xps911 »
You can make it compliant with the settings already available Eddie
crc0069
Post by crc0069 »
I returned home to look at my videos with the overlap. I found the overlap but it says no video. There was and I previewed it. Also I checked under my files and the video is still there. So how do I overlap it if it thinks that the video is not there?
crc0069
Post by crc0069 »
I was wrong all of the videos are gone. I have no idea where they went on the drive home :(
@ crc0069 On which system you are?
crc0069
Post by crc0069 »
Android. Today I tried it at the autox for the first time. Did not get any video. I did see that after my co-driver ran it was saying that the device memory was high or something. Can I make everything that this app do save to the sd card?
