Program finishes when accessing to Lap List
Posted: Mon May 05, 2014 8:38 am
by Slowrider
Every time, when I try to open the Lap List, the program finishes so I cannot access my laps to make an overlay.
In the section Videos, I see all the related videos and the end times for all single laps, so I think, the data are ok.
Is it still possible to open the lap List?
Re: Program finishes when accessing to Lap List
Posted: Mon May 05, 2014 9:22 am
I assume there is something wrong with the database. Please check viewtopic.php?f=8&t=679 and send your databases to me for analysis / repair (Harry@gps-laptimer.de).
Posted: Mon May 05, 2014 10:12 am
by Slowrider
Thank you so much!
I sent it to you a few minutes ago.
Hope, there is a chance for me....
Posted: Thu May 08, 2014 4:24 pm
by Slowrider
It Works! :mrgreen:
Thank you, its very kind, that you help people with problems! :D
Posted: Sat May 31, 2014 12:11 pm
by Slowrider
Now I have the same problem again.
Again every time, when I try to open the Lap List, the program finishes so I cannot access my laps to make an overlay.
And again, all related videos are there.
Should I reinstall the programm?
Posted: Sat May 31, 2014 12:15 pm
No, this will delete the data and the problem will come back again most probably (not a general issue). Please send the data as before and I will check. Is there any pattern (the way you use or finish the app, device configuration, some crashes, low memory situation) you can recognize that results in this type of issue?
Posted: Sat May 31, 2014 1:22 pm
by Slowrider
Thank you, I will send the data.
There was no low batterie, because I charged my ipod all the time in car. Also there was no low memory, I deleted all previous data before.
It was not a known track, therefore I used "autocross" and defined start and finish.
After a few laps, when I wanted to activate Laptimer again, I saw something like "Die Datenbank wird überprüft".
But there were no crashes.
I use an external GPS-Mouse and an OBD-Stick.
Posted: Sat May 31, 2014 1:27 pm
Which iPod touch generation?
Posted: Sat May 31, 2014 1:36 pm
by Slowrider
iPod touch 4G 32GB.
My husband uses exacty the same iPod, and he has no problems.
