Program finishes when accessing to Lap List
Slowrider
Post by Slowrider »
Every time, when I try to open the Lap List, the program finishes so I cannot access my laps to make an overlay.
In the section Videos, I see all the related videos and the end times for all single laps, so I think, the data are ok.
Is it still possible to open the lap List?
Re: Program finishes when accessing to Lap List
I assume there is something wrong with the database. Please check viewtopic.php?f=8&t=679 and send your databases to me for analysis / repair (Harry@gps-laptimer.de).
Slowrider
Post by Slowrider »
Thank you so much!
I sent it to you a few minutes ago.
Hope, there is a chance for me....
Slowrider
Post by Slowrider »
It Works! :mrgreen:
Thank you, its very kind, that you help people with problems! :D
Slowrider
Post by Slowrider »
Now I have the same problem again.
Again every time, when I try to open the Lap List, the program finishes so I cannot access my laps to make an overlay.
And again, all related videos are there.
Should I reinstall the programm?
No, this will delete the data and the problem will come back again most probably (not a general issue). Please send the data as before and I will check. Is there any pattern (the way you use or finish the app, device configuration, some crashes, low memory situation) you can recognize that results in this type of issue?
Slowrider
Post by Slowrider »
Thank you, I will send the data.
There was no low batterie, because I charged my ipod all the time in car. Also there was no low memory, I deleted all previous data before.
It was not a known track, therefore I used "autocross" and defined start and finish.
After a few laps, when I wanted to activate Laptimer again, I saw something like "Die Datenbank wird überprüft".
But there were no crashes.
I use an external GPS-Mouse and an OBD-Stick.
Which iPod touch generation?
Slowrider
Post by Slowrider »
iPod touch 4G 32GB.
My husband uses exacty the same iPod, and he has no problems.
