android video default to sd0
arsprod
Post by arsprod »
My RAZR M creates a virtual SD card sd0 which is actually main memory and laptimer defaults here. I also have an external card which shows as sd1. How can I make laptimer use this (much larger) storage?
Re: android video default to sd0
LapTimer actually should select the external SD card if available. It seems it does not interpret the RAZR configuration correctly.... To fix that, I need you to generate a short log: please check this thread for a description on how to generate logs. Please replace the named OBD trace classes by the "Video" trace class and open the Video List or press the status gadget in Timer at least once while logging is active. Send the result to Harry@gps-laptimer.de and please do not forget to add a link to this thread / your forum name.
arsprod
Post by arsprod »
well, it appears it's fixed! On a lark I restarted the phone and it's now recording to sd1 - go figure!
Have you added the SD card while LapTimer has been active?
arsprod
Post by arsprod »
Harry wrote:Have you added the SD card while LapTimer has been active?
never touched it, just rebooted
