Multicam GoPro Only?
Trail Braker
Post by Trail Braker »
First time using the app last weekend and all worked very well! My question is regarding only using the GoPro for video (iPhone cam off) to save memory space. I have 2 track days coming this weekend and would like to just use HLT for the track data only and combine it with GoPro video in RaceRender after. Can I turn off the iPhone camera in HLT somehow? Sorry if this is obvious, I'm a newbie.
Thanks for a great app!
Re: Multicam GoPro Only?
In case you use LapTimer GrandPrix - which can remote control the HERO - you need to record a second video using the internal cam currently. Change resolution to SD and the result will not require that much memory. I needed to defer that feature beyond v18. In case you do not use GrandPrix remote controlling, you can certainly manually operate the HERO and use LapTimer as a simple data recorder without video.
Trail Braker
Thanks Harry! Yes, using GP v17.5 and all works very well, just looking to save some space. Thanks for the tip, are you planning to add the ability to not use the internal camera moving forward?
Yes, it is on the list :-)
