problem with Send function to share laps
i-Zapp
Post by i-Zapp »
From the lap-list, I am trying to send a lap to another device, and it searches and searches but does not locate any nearby - although there are an iphone and ipad both laying right next to the sending iphone. all three are running v18 of HLT, and have Bluetooth turned on. tried sending from each, tried cycling Bluetooth on/off, and verified that Bluetooth works on each. Any suggestions? We'll have 4 bikes running this coming weekend and very eager to begin sharing!
Re: problem with Send function to share laps
This is due to the BT issue in iOS7.x You may try the new Challenge function to share your data. Just select the best lap you want to shear and press the Challenge button in Lap Details.
i-Zapp
Post by i-Zapp »
Harry wrote:This is due to the BT issue in iOS7.x You may try the new Challenge function to share your data. Just select the best lap you want to share and press the Challenge button in Lap Details
many of the tracks we visit don't have wifi so would not be able to compare laps after each track session.
does this mean that the feature is effectively dead, or is there a workaround or fix in the works?
thanks Harry.
You don't need wifi, this can be any internet connection (on track usually a mobile network). I didn't find the time to look after the D2D transfer lately but will raise priority now that iOS7.1 is out.
