Do you know what map is good for the Nordschleife + GP? I used NOS BTG+GP today and it only recorded from Bridge to the F1 Finish line.. real dissapointment
Just checked NOS BTG + GP and it has no stop trigger at the GP start / finish line. I'd guess you have any of the track sets loaded in addition - one with the GP start / finish line. In this case you should get red exclamation marks and a warning when you open the Lap List?
I thought when I click on the wrench I select the track and driver, but it leaves other tracks active as well? Do I have to delete the other tracks under "manage tracks" and download them again from "add ons" later?
Thanks for the quick solution this is seriously the coolest app ever
You need to purge the POI sections of the conflicting tracks, not the complete track. It is kind of switching between POI sets... Please make sure you have no conflicts. The setting of the current track is for manual timing only. LT uses whatever triggers it finds.
