NordschleifeBTG POI set a bit off
csmarx
Post by csmarx »
Is it just me or does the NordschleifeBTG track set end early? In all the videos, the lap ends significantly before reaching the Gantry. The lap should end when the Gantry is just passing overhead, not when it's still 20 or 30 meters down the track. Agreed? :?
-Christian
Re: NordschleifeBTG POI set a bit off
The track set starts early and ends early too. Check the vids and you will see they all start with a lap time > 0. Actually both triggers should be moved a bit forward. As this would break lap to lap comparison (old vs new), and would not change the overall distance, I haven't changed that so far.
