Will I be able to use the addt'l HLT displays using a BT1 (or any type of OBD reader) with a JDM ECU?
I have a JDM ECU in my Miata. Thanks!
HLT+BT1+ JDM ecu?
Re: HLT+BT1+ JDM ecu?
The ECU / car has to be OBDII compliant for BT1 and HLT to show the additional data. I don't know about the JDM ECU, but OBDII compatibility is what you need to check for.
