Overlaying a video stops after 5%
MaikelvdBrink
Post by MaikelvdBrink »
Hello all,
I recently bought the Laptimer app (Pro Version) from the App Store. Last weekend i was at the Nurburgring and i recorded 2 laps, but when i try to overlay the data it stops after 5% and sometimes immediately. Maybe you guys can help me out!
Maikel
Re: Overlaying a video stops after 5%
Please check your device's memory available.
MaikelvdBrink
Allready checked it, 11,6 GB left. And overlaying still stops after 5%.
Maikel
So can you please check both the video and the GPS data. The video can be checked in the Photo app, the GPS data can be viewed in LapTimer's data recording views (start in Lap Details, press 'Track'). Both should have similar length. What is your iOS version?
MaikelvdBrink
I've reinstalled the app, but before that i've exported the lap to dropbox so the lap data is not in the app anymore. Is there a way to import the lap from dropbox or something?
I currently use iOS 4.2.1.
Maikel
LapTimer can import .hlptrl files from any mal file. Not sure if Dropbox recognizes this correctly. So in case it doesn't, simply send the file to a mailbox you have access to on your iPhone. Press and select LapTimer for opening.
MaikelvdBrink
This weekend same problem for me, overlay stops after 5%. I now checked the length of the video and GPS recording. GPS is 9:57.55 but video is 9:55? Device has enough memory and it still wont work. Please help!
Maikel
The time difference is fine, reason is that video recording requires a few secs before it starts.
On the freeze after 5%: which iOS do you run?
MaikelvdBrink
Harry wrote:The time difference is fine, reason is that video recording requires a few secs before it starts.
I currently use jailbroken iOS 4.2.1! Did a little run today on the streets and that is fine until 12%.
Maikel
As this is a unknown problem with the latest iOS, and both of you run iOS4.2.1, this is probably part of the issue... Please send a note to me using the 'Contact' button. This gives me more information on your system's configuration.
