Varano de Melegari
MrCaymanR
Varano de Melegari
Post by MrCaymanR »
I'm searching for the Varano de Melegari (Italy) track set,
do you have it?
Francesco
Re: Varano de Melegari
Varano (Autodromo Riccardo Paletti) is online. For future request, please check Tracks for a tutorial how to create a track on your own. Contributions from my users are highly welcome.
MrCaymanR
Post by MrCaymanR »
I've been to Varano yesterday and they have changed the last sector of the track, is it possible to update the track?
Thank you,
Francesco
What kind of change? May I ask you to change the track set and 'Re-Certify' it? It should be easy: in v14, goto Lap List, select Varano's POIs. Press the 'Map' button in the bottom. You will be navigated to the Maps view with all Varano POIs visible. Now just drag around / change POIs as you like. Once finished, go back to the POIs in Lap List and press the Certify button. I will update on the server and notify you once it is available.
MrCaymanR
Post by MrCaymanR »
The last sector named as tornantino it's a bit different with 3 small round curves instead of the 1 slow big. I've checked the map now but they don't have updated the map yet. However the sector it's very similar to the one before so i don't think it will interferate with the datas..
Just send me one lap recorded (KML or HLPRL format) once you have recorded it.
