Does anyone know if the camera can be changed on the iphone to record from the front lens? At present, as it only records from rear lens the screen is obscured by the mount bracket?
regards
Paul
Can the camera be changed on iphone 4
mortgagemen
- Fewer than 10 Posts
Re: Can the camera be changed on iphone 4
Hi Paul,
v13.4 supports video recording using the back camera and the device turned to the left only. A lot of mounts I know allow this position, which one do you use?
Good news for v14.0 is a set of added functionality around video recording. This version will support both turns to the right, and the use of the front camera (although it delivers SD videos only).
P.S. @All: No, there is no release date known
mortgagemen
Its just a standard iphone carrier for iphone 4
Will just carry on !! Many thanks
Paul
Paul
- tank.JPG (22.56 KiB) Viewed 3530 times
