after replace IPhone 3GS into 5, no video and no
Exige2010
Post by Exige2010 »
Hi there,
I replaced my Iphone 3GS against a new IPhone 5.
After I installed again Laptimer I can'z record Videos and I miss some kind of views (classic etc.)
At the 3GS the professional version was installed, but this version is no longer available. I got just the Rookie version which is wihout the above features. Is there a possibility to get these features again without pay them again?
thanks in advance
regards
Exige 2010
Re: after replace IPhone 3GS into 5, no video and no
From your description I assume you bought LapTimer Rookie (Standard) initially and later upgraded to Petrolhead (Professional). To get back to this state on your iPhone5 please follow the same steps: 1) load Rookie from AppStore 2) load the Petrolhead Upgrade from LapTimer / Tracks tab. You will be prompted if you want to purchase the Upgrade for xx US$ - ignore this, you will get a message later you have not been charged again. Please check your files / receipts sent by Apple ahead of step 2 to make sure you really had purchased the Professional Upgrade.
Exige2010
Post by Exige2010 »
thanks a lot, it works.
My problem was, that I read in the description of the Apps in the Apple App store, that also the basic, Rookie version has the Video function. That's why I thougt it should work with the Rookie version. May be this description should be modified.
Have a nice weekend!
Yes, you are right. I use one text for all editions, need to be more specific here.
