GoPoint BT1 not working now with HLT.
TTrevoRS
Post by TTrevoRS »
I've been successfully using the GoPoint BT1 with HLT with my previous iPhone 4S. I upgraded the phone this year to iPhone 5 and at my first event at Mid-Ohio the OBD info is not coming across. The BT1 is working with the GoPoint apps, so that update has taken place.
After checking out the forum, I went to the app to see the "settings" and it is not there, no way to check on what information is being requested/sent.
Any thoughts?
Regards,
Trevor.
Re: GoPoint BT1 not working now with HLT.
What do you see in Sensors while the BT1 is plugged in and the engine in running? There are no settings for the BT1 you need to adjust.
TTrevoRS
Post by TTrevoRS »
How do I get to Sensors from here:
I assume they are under Settings?
Trevor
It seems you have turned off advanced mode (which hides several views). To reveal the Sensor List, please select the Guide tab, select "Define User", and turn on Advanced Mode again. Afterwards, you will see a new tab named "Sensors".
TTrevoRS
Post by TTrevoRS »
Here is what it says. Thanks for the previous tip.
Regards,
Trevor
Hi Trevor,
This OBD Sensor Information looks pretty strange. Please enter LapTimer ‣ Settings ‣ Expert Settings ‣ OBD Tweaks. Make sure Exclude PIDs (...) is empty. In case it is not, please turn Auto Exclude PIDs OFF and clear the Exclude PIDs setting. Once you have done this, please try connect your OBD and try again.
TTrevoRS
Post by TTrevoRS »
Here is the new Sensor Screen, it seems to be working now. I'll try it at the Glen next week and let you know.
Should I exclude any PIDs?
Trevor.
Great!
Please do not exclude PIDs except they cause trouble. As long as you get an OBD update rate > 0Hz, everything is fine.
