Heartland Park Topeka has two start/stop triggers
Dr_Pippin
Post by Dr_Pippin »
Just purchased the app today. Really looking forward to getting to use it. While browsing the local tracks, I noticed Heartland Park Topeka has two start/stop triggers:
On the map you can see they are very close to each other:
The lower trigger is correctly on the finish line, however the upper trigger appears to be on the hot pit lane? Would this be intentional? Should I delete the duplicate trigger (the one not directly on the start/finish line) and re-submit the track to you for certification? I read on the website you don't like doing that because it erases all previous lap times. If it's something you can fix without me doing anything, then that would be great.
Re: Heartland Park Topeka has two start/stop triggers
Well spotted, that is not correct. I removed the trigger on the pit lane side and uploaded it to the server.
