I have set up 11 splits on a track but only 1-9 are listed in the Lap Results or are shown on Charts.
Are splits currently limited to a maximum of 9 or is there something I can configure to get splits 10-11 to appear. I've attached the track with the 11 splits.
Splits 10 or Greater Are Ignored
- ThndrhlBpsMWH.hpoil
- (5.35 KiB) Downloaded 262 times
Re: Splits 10 or Greater Are Ignored
The max number of splits is 8 (making 9 sectors). That is designed to allow split definitions like those used for racing events (GP tracks typically come with 3, max 4 splits). In case you need analysis beyond this levels, you need to use all the continuous analytics provided in LT's Data Recording Area.
