Lap Times not even close?
Fire_2
Post by Fire_2 »
OK, so I did an evening session around brands hatch, (England) Indy circuit the other night.
connected via my xgps150 at 3.9/4.0 hz
compression was default set to low
and its giving me random times around 1.30 and 1.11...
while my gopro video footage is showing me 59 or 1min laps.
why could this be?
Re: Lap Times not even close?
Please send one lap you consider wrong using the .hlptrl format. This would be the first case LapTimer timed wrong with correct data ;-)
rscliofan
Post by rscliofan »
Harry could it be an issue with brands indi?
as i've pointed out you can not see my time in the hall of fame but also laps that were there before by me have also disappeared off the hall of fame.
Will check the server. I need to update the server application to process the load and amount of laps coming in ;-)
Not related to the thread however ;-)
