fay de bretagne track
xps911
Post by xps911 »
I'm just looking at the track, and only has a start and finish, I want to add some sectors to it, which I have done (3 around the track), but cant test until I am on track.
I just want some opinions, it is worth adding every corner as a split as corner 1, 2 etc ? leave it how I have done it with 3 splits split around? Is this is what is normally done?
thanks
Re: fay de bretagne track
For standard GP length track, 2 or 3 splits are the standard. In case you want to run comparisons by corner, I'd recommend using the Data Recordings graphs. Please check the recent posts on a discussion were to place splits best - we had that within the last week.
xps911
Post by xps911 »
will it auto do speed on corner etc ?
It will automatically show local minimum and maximum values. To get corner names, they certainly need to be defined in the track set.
xps911
Post by xps911 »
and i add them as an information ? if i dont put in corner 1 etc, it will still display corner speeds ?
These are no corner speeds... On a track you typically drive between max and min speeds - straights and corners. LapTimer identifies these max/min values and displays them.
Information POIs are not related directly. Once you approach their position, the overlay will insert them animated.
xps911
Post by xps911 »
ah ok many thanks
im sure it will all make sense once i have done a track day with it
