OBD readout on overlay
Hi, can you specify what is overlayed? im using the petrolhead 17.0.2 thanks
Re: OBD readout on overlay
LapTimer's overlay is not fully customizable. Things you can change are available as a dialog named "Overlay Configuration" you get when pressing the "Overlay" button in Lap Details.
thanks harry, on my vehicle, will it only pick up the rpm from the odb ?
The overlay shows RPM, throttle position, gear, wheel speed, and turbo boost.
Other OBD values are stored and/or displayed elsewhere. Please check the OBD documentation available on www.gps-laptimer.de
Hi it isn't showing turbo boost on my overlay?
Can you please check your OBD PID list (it is visible in your Vehicle Details while OBD is connected) for "MAP". In case it is not delivered, LapTimer cannot show boost. Please check your vehicle settings in addition: Vehicles ‣ Vehicle XY ‣ Engine ‣ Intake ‣ Turbocharged. Do you get the turbo boost gauge when watching the life video view? I tested at least this lately.
How do I check pid list?
With the OBD connected to your iPhone:
Vehicle List ‣ the current vehicle ‣ Vehicle Details ‣ in the bottom
or
Sensor List ‣ touch the blue arrow of the active OBD row
or
sorry for the delay, find attached
- photo 4.jpg (69.24 KiB) Viewed 8118 times
It is also listed as turbo-charged under the vehicle list
