Drive ratios
rscliofan
Drive ratios
Post by rscliofan »
can't find any info on one of my cars :roll:
all i seem to be able to find is the following but it doesn't seem right and can't be imputed into HLT is it won't accept it.
Gearbox
No. forward gears 6
Gearbox Type Manual TL4 031
Vehicle speeds mph @ 1,000 rpm (ratios)
1st 4.91 0.2973
2nd 7.84 0.475
3rd 10.87 0.6585
4th 13.70 0.8293
5th 17.00 1.0294
6th 20.36 1.2333
Final Drive 16/69 = 0.2319
any ideas?
Re: Drive ratios
What exact brand / model / year is your car?
rscliofan
Re: Drive ratios
Post by rscliofan »
It's for a 2010 RenaultSport Clio 200
There is nothing in the technical data on the website regarding the drive ad nor in the brochure I still have.
I've found them for my megane no problem but not for the Clio just the above.
It has a different 1,2 & 3rd ratio but the same 5 & 6th as in the 197.
Re: Drive ratios
It is in German, but probably readable: http://www.sportauto.de/technische-date ... 83902.html
This is what you need:
Gear #1 3,36
Gear #2 2,11
Gear #3 1,52
Gear #4 1,21
Gear #5 0,97
Gear #6 0,81
Drive 4,31
Wheels
215/45 R 17 W
215/45 R 17 W
Engine
201 PS (148 kW) @ 7100 rpm
215 Nm @ 5400 rpm
No idea on the max rpm, but maybe 7500?
rscliofan
Re: Drive ratios
Post by rscliofan »
Nice one harry :D
going on mine of Final Drive 16/69 = 0.2319
so 69 divided by 16 is 4.3125
and that data is Drive 4,31 so yeah thats right.
max rpm is 7250 i think but i will double check.
Thank you once again :D
