Speed Multiplier per vehicle.
Btwyx
Post by Btwyx  »
I've been looking for the correction for the OBD speed, I finally found "Speed Multiplier" in the expert settings. The problem with that is its not per vehicle. I'm running different sized tires on our two cars, so I need a 0.98 correction for one and a 0.92 correction for the other. It would make a lot of sense if this setting were per vehicle.
Re: Speed Multiplier per vehicle.
Yes, in terms of a correct model, the speed multiplier should be a vehicle property. The reason it is not is it is a workaround for rare situations, nothing a lot of people use. So instead of making the vehicle model more complicated, it is an Expert Setting today. I will add this feature request to my list and reflect on it the next time I change the vehicle storage scheme (there are several requests in this area). Thanks!
