Start/Stop with angle
cyril94440
Post by cyril94440 »
Hello ,
just find a little issue.
I've set a start/stop on the road with an angle (perpendicular line).
It triggers fine. But in the other way too !
Re: Start/Stop with angle
HLT doesn't take direction of movement into account. I think this is planned for the next version.
cyril94440
I thouht it does since the last release
Yes, I had documented that on my developer blog on www.facebook.com/HarrysLapTimer some time ago. However, it did not make it to a production release so far...
cyril94440
Ok !
Little question : what is the Speed limit for triggering with/without the allow low Speed switch ?
It is 4.5km/h or 2.8mph
cyril94440
With or without ?
As long as the allow low speed switch is ON, speed is not checked when detecting triggers, when switched OFF, it does trigger only in case speed is above 4.5/2.8.
