LT Pro + Circuit Tools
ajk_race
Post by ajk_race »
Could anyone give me advice? I have newest version of both, downloaded today.
I can export my data to CT but...
- CT reconizes there's 3 laps in example file but cannot determine the lap end/start
- CT shows no track map (custom track), hence start/stop wizard does not work as you cannot define the finish line or splits.
- On data channels lat and lon GPS values show viable values but CT cannot determine the track layout.
Other than that - seems to work.
Help highly appreciated :)
Re: LT Pro + Circuit Tools
There is a known issue with the current VBO export. In case you used the internal GPS sensor, there is no information on satellites available and LapTimer exports "000". This is interpreted as invalid fix by CT and it will not work. To work around, please open the VBO file with a plain text editor and replace the 0-s in the first column by e.g. 10.
Will be fixed in 16.8 which is expected end of January.
ajk_race
Post by ajk_race »
Yes, I used the internal GPS as I was just experimenting. Thanks for the advice!
