Throttle position graph needed
Either a separate graph to compare throttle position vs distance in different laps or include it as an overlay on the speed or rpm graph. It's the only way to tell if you actually went flat out through a corner or your brain stem made you lift your right foot.
Re: Throttle position graph needed
Yes, I'll add this to my list. Next version will feature additional charts anyway, including Yaw Rate, and engine temperatures.
