Re: Converting gear ratio to compatible value for Laptimer
Posted: Sun Feb 20, 2022 8:37 pm
				I understand where are you heading, and yes I fully understand the fact about gears and they should go from the highest to the lowest, but this is not this case. I uploaded printcreen from the official SEAT (VW) technical brochure, as you can see even the manufacturer states that the fifth gear is higher than fourth and sixth.
That´s why I´m so confused about it.
