Recorded in Master mode with no Pip input
SupeR53
Re: Recorded in Master mode with no Pip input
Post by SupeR53 »
Thanks Harry,
Its invaluable to have you to help out. In my expert settings, I've got Ignore NO DATA/NAK Replies checked, not sure if I did this by accident or not, please confirm that it SHOULD be checked. Using Android's latest update and V20 HLT.
Default is having it checked. I had it uncheck formerly - which made any issue visible immediately: LapTimer drops the connection completely and reconnects. The problem has been even an intermittent problem created this drop. On the other hand, getting NO DATA regularly will drop the update rate greatly and you will not get an immediate feedback like before. So pros and cons. In case everything is fine with communication, its value is irrelevant.
SupeR53
Post by SupeR53 »
I'll do some work with the manual data acquisition and let you know what I find. Re: no OBD data
