Having Trouble Deleting Laps
Dubbedown
Post by Dubbedown »
Downloaded the latest update to HLT as of Oct 4, 2013. Running ios7 on iPhone 5. When trying to clean up my lap lists, after deleting one or two the ones after just freeze. It says deleting but even after a minute or so it won't delete. I restart app and phone but same outcome.
Re: Having Trouble Deleting Laps
Please let me know which lap status this "hanging" laps have (i. e. with or without video), and which operation you use to delete (swipe, from details, Edit + delete).
Dubbedown
Post by Dubbedown »
With video, I was about to add if I try to delete by pressing edit, then it's ok. It's the swipe function that hangs on the 3rd or 4th lap. But I know the lap does delete because when I restart the app the lap is no longer there. When it hangs, you see the status icon circle rotating and "deleting lap" appears but never ends.
Thanks, so it hangs with the Deleting Lap and activity indicator exactly when the lap deleted has a video and a swipe action is used?
Dubbedown
Post by Dubbedown »
Correct
O.k. I will check for the next bug fix release, think I know what the problem is... Till then, just don't swipe but one of the other deletion patterns.
TTrevoRS
Post by TTrevoRS »
Same issue here with swipe. Good to know the other method.
