Bluetooth lap-export between Iphone 4S and Iphone 4 !
Haratchi
Post by Haratchi »
Bluetooth lap-export between Iphone 4S and Ipad 4 not possible on IOS 7, after the last update !
Re: Bluetooth lap-export between Iphone 4S and Iphone 4 !
Do you "Send" a lap from it's Lap Details on one iPhone, and "Receive Lap from Friend" (available now in "Export" in the bottom of "Lap List")?
Haratchi
Post by Haratchi »
Yes, that's correct ! :-)
Send from iphone to the Ipad, than accepted...but it doesn't work ! The lap doesn't appear on the iphone like on IOS6 !
O.k., will check that.
Tested sending from an iOS6 to an iOS7 device and vice versa... Both with the latest LapTimer.
iOS6 -> iOS7 works and displays the transferred lap
iOS7 -> iOS6 seems to work but does not receive the lap nor displays it
I will see what I can do...
Hi again,
I checked with the Apple developer forum and this is indeed a bug / changed behavior in iOS7. I will add a workaround to the next LapTimer bug fix release I submit (most probably tomorrow). Please note this issue is not related to any LapTimer version you use or do not use, but depends on the iOS version used only.
Sorry for any inconvenience.
bulls23
Post by bulls23 »
Tried the export / import via Bluetooth using an iPhone 5 and 4, both on iOS 7.02. Works fine, just one minor remark: the send / accept dialogs aren't localized.
You mean the "Waiting for XY"? That's an iOS dialog - and it is indeed not localized :-) In case you see any other dialogs not localized, please send the string. I checked it but couldn't find more than the "Waiting..." above.
bulls23
Post by bulls23 »
Then the others must be from iOS too. Starts with: Looking for other iPad etc...then: Choose an iPad etc...and then: Waiting for...and on the other side 'XXX' Would like to connect. The buttons are also in English despite my iPhones being set to German. Looks like the guys at Apple are getting lazy ;-)
Yes, they are all from iOS. Probably a feature not used too often.
