Android and Qstarz 818XT GPS not working
Re: Android and Qstarz 818XT GPS not working
In case you are willing to do some more debugging, please go through the following steps:
  • Start LapTimer and switch to Settings -> Expert Settings.
  • Scroll to the Tracing options area, tick "Sensor Connection" and "Sensors".
  • Turn on tracing by selecting "Logfile" from "Type".
  • Go through the BT adding steps in Sensor List.
  • Wait some seconds.
  • Go back to Settings -> Expert Settings and select "Send Logfile (if available)"
  • Send the log file mail generated to me
StuartG
Post by StuartG »
Done -- it should be on it's way to you. I tried selecting the BT GPS a couple of times, then sent the log.
-Stuart-
StuartG
Post by StuartG »
Did the log come through? I tried sending another (a few days ago) after you did not receive the original one.
No, I haven't received your logs. Please try to send it to yourself and forward it afterwards. Thanks.
StuartG
Post by StuartG »
Do I send the logs to myself by setting the "Default E-Mail" in the Export section of Expert Settings? Currently it is blank. Or is there a different procedure? Thanks,
-Stuart-
This is a convenience option only. In case you export data and logs ;-) frequently, setting the default email address in LapTimer's Settings will make life easier. LapTimer will prepare the mail generated with this e-mail address. In case it is not set, you need to enter the e-mail address directly in your mail client every time you send a mail.
