Can't find GoPro video after importing?
MattC813
Post by MattC813 »
Hey all,
I've edited my gopro video using both VLC and iTunes, yet when I go into HLT, it still cannot locate the video for the PIP, any advice? I just upgraded to the Grand PRix version, so I could be making a rookie mistake here. I've read the guides, and followed them (seemingly) step-by-step, but no luck. Any suggestions? Thanks guys!
Matt
Re: Can't find GoPro video after importing?
Please check you see the video in the Photo(!) app first. If not, there is an issue with iTunes synchronization and you need to adjust the settings. Please check next the Metadata has really been stored. Depending on the video format, VLC successfully stores, or fails to store... You can check that easily be re-opening the video in VLC and checking the Genre field.
MattC813
Post by MattC813 »
Ah I see, the video was placed in the "Videos" app, so it specifically needs to be in the "photos" app correct?
Yes, correct. The Video app's repository is not accessible from outside, so Photo is the way to go.
MattC813
Post by MattC813 »
Thanks! Once home I will move to photos and see if it works!
