Le Mans Maison Blanche and Le Mans Circuit Bugatti
Re: Le Mans Maison Blanche and Le Mans Circuit Bugatti
The layout you will be driving was obvious with the first link you provided...still no start/finish line in the drawing as minimum requirement.
it's where the first arrow is on the straight when you exit out of pits.
has the corner names here as well
- trackmb.jpg (208.29 KiB) Viewed 7052 times
I would really like to help...but the hand drawing and the track layout you linked at trackdays.co.uk are two different track layouts...is start finish the same and which layout are you going to drive? 1, 2, 3 or 4 according to this picture:
ignore the link from trackdays, the one i posted above is from organisers
So it should be layout number 1 (red line).
Seems you owe bulls23 some glasses of beerxps911 wrote:yep!
Just submitted the track set, hope the positioning is good enough. Used your graphic as an overlay in Google Earth. Let me know how it worked out and spread the word to get some new Laptimer fans during your track days
Sent from my iPhone using Tapatalk 2
ohh thank you
harry> did you get my updated fey de bretagne ?
