Missing Settings Menu
Tango Mango
Post by Tango Mango »
I have 2 Iphone 4s that I want to link together to use multicam. The new Iphone has more memory so I want to use it as the master.
I upgraded from Petrolhead to Gran Prix on my new Iphone but just noticed that the Laptimer on my new Iphone is missing the following menus under "more": racers, classic, speedo, satellites, settings and sensor list. I think I need the settings menu to set up the multicam feature.
Can you let me know how to get the settings menu installed? If possible, I would also like to get the other menus installed but they are less critical to me at this point.
Re: Missing Settings Menu
So this is the dialog you decided to ignore :-D
Srcypher
Post by Srcypher »
I wish the easy mode was my problem; I had the full suite of settings on my ipad, and then they were all gone when i was setting up multi cam; I can't find what I turned off/on, and I am in advanced mode...please advise. I set up a local map for testing, icloud to sharethe video, and now I can't get to any map. I have the "hide tab" on, but the tab doesn't hide itself. Please tell me what I screwed up.
Hmm, not all views are available in landscape, but you have tested both orientations for sure? In case Settings is still missing, please do the following:
1) make sure you are on the latest version
2) rotate the iPad to portrait
3) press the More tab and Edit afterwards
4) generate a screenshot (Home+Sleep button at the same time)
5) send that snapshot to me (Harry@gps-laptimer.de) or post it here
Srcypher
Post by Srcypher »
I feel like...
