roqyBT4 and Bluetooth OBDs!
rscliofan
Re: roqyBT4 and Bluetooth OBDs!
Post by rscliofan »
anyone else having issues with roqybt4 after 6.X? I'm now on 6.1 and my obd reader appears to connect but won't transmit/receive data?
rscliofan
Post by rscliofan »
As you can see its shown at the bottom
But I also see apple is also seeing it which it's never done?
Perhaps it's interfering with it?
I cannot comment on the Apple BT / roqyBT relation (check with the roqyBT people). The first screenshot means the OBD is detected but the request / reply dialog is not started successfully (so actually not communication).
rscliofan
Post by rscliofan »
Yeah I know it's not officially supported so I wondered if I'd set it up as before but it seems to be just not passing data.
rscliofan
Post by rscliofan »
Does anyone know if BTstack would open the reader up?
rscliofan
Post by rscliofan »
I'm not sure it's roqy, I'm 200 miles away from my car yet HLT it still shows connected.
I knows it's not supported so it would be good to know if its just me who is having issues?
roqyBT
Post by roqyBT »
For roqyBT support don't forget to write to support @ roqy-bluetooth.net ! I don't know why you don't see any data here, feel free to write. I tested it on DashCommand with iOS 6.1, no issue, everything worked great.
I updated roqyBT4 to 1.4.0 to correct issues with disconnection.
Use only roqyBT4 interface to pair with OBD devices.
Roqy
rscliofan
Post by rscliofan »
Roqy sorry I should have updated this.
I was the one who told you about the Erica Utilities.
Works perfect now thank you.
mx1000
Post by mx1000 »
I just ordered RoqyBT4 and Harry's Lap Timer Trainer. ;)
I'm using an Ipad Mini, jailbreaked with an ELM 327 connector.
And I have exactly the same issue as described above :
->ELM 327 detected
->Roqy BT says OBD Server Started @ 127.0.0.1:35000
->Harry's Lap Timer shows the OBD sensor connected @ 0.0Hz
But there isn't any ODB data readable for HLT. :roll:
Rscliofan, what was your fix ?
rscliofan
Post by rscliofan »
did you set the obd pass key to the correct setting in RogyBT4 configuration? (1234 usually). Also set automatic paring on data request to ON and in laptimer expert settings? More tab ->settings->expert settings-> in obd tweaks custom host needs setting to 127.0.0.1 and custom host 35000
