Croix-en-ternois, France
KiSwiSje
Post by KiSwiSje »
I noticed the names of the corners are wrong - I mailed the people from the track for the correct names - I'd be glad to change them for the official names.
The start/stop poi seems ok - I have used the track in Laptimer before and it worked ok.
So I guess - as long as the start/stop trigger is the same - it wont make any difference for people that have laps.
Full credits off course to the original submitter of the track.
Tracé Circuit2.jpg (59.61 KiB) Viewed 6151 times
Thanks for taking care. Please just change the corner names and press the Certify button for the track set afterwards. Please add a comment that only corners has been changed.
KiSwiSje
Re: Croix-en-ternois, France
Post by KiSwiSje »
done
sent for certification
KiSwiSje
Post by KiSwiSje »
Harry, I sent the track with new names of corners for certification, did you receive it?
Yes, think so. Please give me some time, I have a huge backlog to work on. :-)
KiSwiSje
Post by KiSwiSje »
I just updated the track list, and downloaded the track
nothing has changed, still the old info
Maybe I am too soon to try?
Or am I doing something wrong?
No hurry - just let me know if you want me to do something
Thought I had uploaded it yesterday evening (GMT), but will check again.
My fault, copied to the wrong directory... It is online now.
KiSwiSje
Post by KiSwiSje »
sorry to bother you again, but something went wrong
i see you changed something (added my name to the source), but for some reason the poi's are still the same
simple check - the original had 6 poi's, the updated version has 8.
(added a track name, and one corner, changed names and positions of the other corners, did not change the start/stop poi)
KiSwiSje
Post by KiSwiSje »
Just gave it another try - same result
I updated the tracks list
i downloaded croix-en-ternois, the source shows my name(look under the 'ok' button), but it loads 6 poi's, and they are the old names
Is there some sort of caching mechanism that could be causing this ? do i need to reload the entire track list?
let me know what you want me to do to test this
