1, 4, 5, 8hz XGPS150A
Crumpet
Post by Crumpet »
Hi guys,
Noobie question. The XGPS150A is advertised as 4 or 5hz but in the sensor settings I can also choose 8hz
Will it work at 8hz and not cause issues?
Re: 1, 4, 5, 8hz XGPS150A
I believe there has been a special firmware that allowed this rate. Not sure, it is really long ago. Try it and check the actual rate in LapTimer ‣ Analysis ‣ Realtime ‣ GPS.
