[SOLVED] NJMP Thunderbolt- track map and full red tach
zxces50
Post by zxces50 »
Uprev'd to 15.4
@ thunderbolt today - Load track map but would never auto start (Using PLX and emprum GPS- both show up as connected) I manually started after session already began.
The Tach shows up as solid red circle and no #'s. Needle reads correctly- in vehicle definition list max rev as 7800RPM - stumped why red tach
zxces50
Re: NJMP Thunderbolt- track map and full red tach
Post by zxces50 »
here is video
http://youtu.be/V3ht1aX7Wn0
Will re-enter car data max torgue/rpm & max HP/ rpm & red line to see if fix etc
For the red circle, please check the Max RPM Setting of your vehicle.
zxces50
Post by zxces50 »
yes that was the fix- I just deleted vehicle and re-entered data.
Hi again,
It is just becoming evident that users with high precision external GPS mouses (Dual, Emprum) have problems with missed triggers / laps not recorded more often compared to others... Please read this article for reasons and a work around: viewtopic.php?f=8&t=617&p=3036#p3036
